Rajita
Feb 15, 2019Aspirant
Multicast issues with M4100-26G v2
Hi,
I am trying to implement multicast using IGMP snooping. I am using single switch and 2 systems (1 for multicast client and 1 for multicast server)I have following setup of switch:
In switchin...
LaurentMa
Mar 07, 2019NETGEAR Expert
Hi, sorry for your issue. It must be a configuration issue with IGMP here.
Please make sure the IGMP Snooping, IGMP Querier(v2) and IGMP Fast Leave are properly configured at the VLAN level (not at the port / physical interface level). Can you follow the direction from this post (I indicated how to configure IGMP for VLAN 2, please replicate it in your case for VLAN 1): https://community.netgear.com/t5/Pro-AV-over-IP-Switches/M4300-configuration-as-AV-network-access-switch/m-p/1717479#M114
I know the other post in for M4300 and you have a M4100, but the menus are consistent in the GUI.
Please let us know.
Rajita
Mar 08, 2019Aspirant
I have attached my swicth configuration. Please let me know if you face any issue opening the same.
My setup as I explained earlier is:
1- Ubuntu System having two interfaces. (192.168.0.1/16 and 192.168.1.43/24)
2- Netgear M4100-26G
3- Another Ubuntu System (192.168.1.37/24)
4- Interfaces of both ubuntu systems are connected to netgear switch. From 192.168.0.1/16 I have netgear web interface opened.
5-192.168.1.37 is sending IP multicast frames at group address 239.1.1.1.
6-192.168.1.43 is subscribing to 239.1.1.1 group by sending IGMP request.
Issues:
1- Join request with IGMP version 2 doesn't work.
2- I had to force igmp version 3 on 192.168.1.43. Only then I started recieving multicast frames on system 192.168.1.43 and can see the entry in MFDB table. In this case After 260 seconds netgear stops sending the frames.
- RajitaMar 09, 2019AspirantAnd Why querier ip is not coming as 0.0.0.0?check the Wireshark capture and config images.
- LaurentMaMar 11, 2019NETGEAR Expert
I am sorry for the issue you are encountering. The IGMP Querier IP address isn't meant to be 0.0.0.0 in your packet captures, this is a configuration setting taken into account by the switch during the Querier election, after that the switch is using its management IP address on the network.
I reviewed all your screenshots and the switch configuration looks OK to me. It makes sense for the IGMP version, the switch is using IGMP Snooping v3 and IGMP Querier v2. The one thing we can't control in your posts is the Linux server configuration (PC1 and PC2). Did you validate the servers' behavior is correct, can you check with another switch or make screenshots of your settings here. I am afraid the IGMP Snooping doesn't behave correctly due to some miscommunication here?
Thanks,
- schumakuMar 11, 2019Guru - Experienced User
Two subnets with overlapping addess ranges is already a bad starting point.
