krobinson
May 17, 2017Tutor
Multicast traffic only goes in one direction (need to send multi cast back)
We have a igmp layer 2 network for multicast video traffic. I am able to join multicast traffic in "one direction" Source A and TV A ---> M5300-52G3 --> LAG --> GS752TS --> Source B and TV B ...
Retired_Member
May 17, 2017Hi krobinson,
Welcome to the community! ![]()
Could you please check whether enable IGMP Snooping in the VLAN or Interface both for TV A and TV B.
As Switch will generate MFDB table and IGMP Group entities only when enable IGMP Snooping in the VLAN or Interface.
Hope it helps!
EricZ
NETGEAR employee
- krobinsonMay 18, 2017Tutor
Yes, IGMP snooping is enabled on all ports including the LAG.
When I have querier enabled on both switches the M5300-52G3 enables "Multicast Router" (under the IGMP Snooping Section) on the LAG. This sends ALL the video down the lag (over 4gigs of data). I will get video breakup in this situration.
I do notice that if I disable querier GS752TS and have TV B connect to a mulitcast from Source B, then TV A is able to connect to the same multicast but nothing else.
How is MLD snooping different than IGMP snoopping?
- Retired_MemberMay 20, 2017
Hi krobinson,
MLD Snooping function behavior is same as IGMP Snooping, just for IPv6/IPv4 protocol.
Could you please provide configuration file to us for further analysis?
How do I send configure files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/3143
9 - krobinsonMay 23, 2017Tutor
