krobinson
May 17, 2017Tutor
Multicast traffic only goes in one direction (need to send multi cast back)
We have a igmp layer 2 network for multicast video traffic. I am able to join multicast traffic in "one direction" Source A and TV A ---> M5300-52G3 --> LAG --> GS752TS --> Source B and TV B ...
Retired_Member
May 24, 2017Hi krobinson,
Please see my comments in line:
2. enable igmp snooping on vlans only, disable per port configuration. Is this the desired configuration for both swiches??
Yes, only enable on related VLANs for both switches.
krobinson
May 31, 2017Tutor
EricZ
There was no change when I disabled IGMP on a per port configuration.
any other ideas??
- Retired_MemberJun 01, 2017
Hi krobinson,
I have no idea any more.
It would be best that you open an online case with NETGEAR Support for further assistance. Kindly state your concern and the troubleshooting steps you've done so far to isolate the problem.
