Ramen's avatar
Ramen
Need help with trunk two M7100-24X switches
I'm currently using two of these switches for our SAN network. I'm trying to connect both switches together but no sucess at the moment. I have vlan 80 set for iSCSI and set it as T for one port I'...
  • Retired_Member's avatar
    Retired_Member
    Jan 18, 2017
    Hi Ramen,
    According your coments and scenario, I think the support suggest you to use MLAG. But it depend on the host1, does it support setting LAG for two ports?
    For MLAG configuraiton and apply scenario, please refer to the link.
    Hope it can helps!
    Ericz
    NETGEAR Employee
ProSupport for Business
