aviator2010
Jul 31, 2024Aspirant
Need to do a factory reset on m4300 switch
Hi I have the following problem with a switch : U-Boot 2012.10-00258-g1c5018gfe9 (Jul 26 2019 - 11:22:39)VerNo=1.0.0.15 UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19 ...
RennaD
Aug 07, 2024NETGEAR Moderator
Hi aviator2010,
Welcome to the NETGEAR Community! 🙂
I suggest to contact NETGEAR support team and open a case about your issue. I believe there is a way to recover the switch when the permanent storage has been deleted.
https://www.netgear.com/about/contact-us/
RennaD
NETGEAR Team
- aviator2010Aug 07, 2024Aspirant
Aman,
re. this question:
This is regarding your case 48430260
Could you please tell me what is the power LED indication you are getting on the switch while it is powered on?As you will see with the detail i provided, the system is powered on - it gets through a boot sequence of sorts as my captured screen information eludes to, what are you asking here in exactly to 'power lED indication' when the system is clearly on.
- RennaDAug 07, 2024NETGEAR Moderator
Hi aviator2010,
I see that you have already contacted support. For the case to progress, please provide update to it by logging in to https://my.netgear.com/ and go to Support tab.
RennaD
NETGEAR Team
