ShimmyShoo
Sep 27, 2016Aspirant
Netgear FS305-100PES No DHCP
Hi guys, im facing the issue in the following setup: Router splitet to a computer directly and my netgear switch (FS305-100PES). i added 2 network devices on the switch but cant find them as ...
JohnRo
Sep 28, 2016NETGEAR Employee Retired
Hello ShimmyShoo,
Welcome to the community!
The FS305 is only a plug-and-play device and it does not have any configuration. Check the cables that you are using and make sure that the connections are correct. Can you confirm if this is how your setup looks like. Modem>Router>Switch>Computers.
Thanks,
