masejucr
Apr 24, 2016Follower
Netgear GS110TP POE not working
GS110TP B5.1.0.2 5.4.2.22 POE ports do not work. POE ports do not power POE devices. I have tried all posible settings and POE devices will not power up. Please note that POE devices ...
DaneA
Apr 25, 2016NETGEAR Employee Retired
Hi masejucr,
Welcome to the community! :)
Let's isolate the problem. Kindly answer the questions below:
a. Is the PoE function of the GS110TP working before?
b. On the web-GUI of the GS110TP, go to System > PoE > Advanced > PoE Port Configuration. Does it show "Enable" on the Admin Mode?
c. From question b, what is the Status of each port when a powered device(s) are connected?
d. Have you tried to reboot the GS110TP?
e. Did you try to perform a factory reset on the GS110TP then reconfigure it from scratch and check if same problem will occur?
I look forward to your response.
DaneA
NETGEAR Community Team
max-bit
Jun 17, 2016Aspirant
In these models, mass be corrupted by power PoE via Ethernet ports.
NetGear knows the problem and therefore avoids repairs and looking for reasons not to repair or replace the equipment.
Sam I have a problem and netgear I do not want to replace equipment
- DaneAJun 20, 2016NETGEAR Employee Retired
I just want to follow-up about your concern.
I believe that if ever all of the troubleshooting steps has been exhausted and the NETGEAR device has been proven that its faulty and as long as it is within the hardware warranty, an online replacement will be granted to the owner of the NETGEAR device.
DaneA
- max-bitJun 20, 2016Aspirant
Currently, the case for support has been abandoned. But I did not give up the case, because the support Netgear is only theoretical.
If so, forward the case, the units of the European Commission.
They will look at the practices used by Netgear.
