StefanV3
Jun 15, 2020Aspirant
Netgear GSM7224v1 does not allow keyboard input in ezconfig via telnet connection
Hi, i recently bought an old Netgear GSM7224 Switch. It works fine so far but i have a little problem with "ezconfig" via telnet connection. I use PuTTY for telnet connection and i am able to...
StefanV3
Jun 21, 2020Aspirant
Hi,
Thanks for your answer.
Yes, after restart WebGUI is available and I am able to navigate.
The Firmware installed is the latest available v6.2.0.14
Are there any settings that have to apply in Webinterface of the Switch?
Thanks
StefanV3
Thanks
StefanV3
DaneA
Jun 23, 2020NETGEAR Employee Retired
Thanks for your response. It's good to know that you are still able to navigate through the web-GUI but I found out that there is no option to factory reset the GSM7224v1 through the web-GUI.
Since you are able to access the GSM7224v1 via console connection through the COM Port ,let us try to reset the GSM7224v1 to factory default settings then reconfigure it from scratch. Then, observe if the same problem occurs such as a restart is needed in order to access its web-GUI and check the telnet access.
DaneA
NETGEAR Community Team
