Blitz2016
Apr 06, 2016Aspirant
Netgear M4100-D12 Documentaion for Resetting Passwords via Hyperterminal Inconsistencies
I tried to go into the M4100-D12 to reset passwords via the Hyperterminal instructions and had nothing but problems. First Hyperterminal for Windows 10 does not exist. You have to get a trial co...
DaneA
Apr 06, 2016NETGEAR Employee Retired
Hi Blitz2016,
Let me share these articles below if ever you have not yet came across with it:
M4100:To recover admin password from boot menu
Unable to access a M4100 series user interface by HTTP or Telnet
DaneA
NETGEAR Community Team
- Blitz2016Apr 06, 2016Aspirant
Dane,
Thanks for responding.
That is the 3rd set of settings I have seen. The main problem is Netgear web site has multiple pages for the same item. And they are not in sync...
Correct serial settings:
115200,N,8,1 and NO FLOW CONTROL
Checking for application q (you enter "q" within 2 seconds of seeing that line)
It would still be nice to see a Hyperterminal program like app from Netgear (at least a recommended one) since Hyperterminal is no longer supported in new versions of Windows. I have 27 (?) days remaining in the free trial program I scrounged. But then what?
Plowing along and at least greatful I can finally interect with the Netgear unit serial stuff.
Anyone know the correct password for the "17 - Start Diagnostics Application" ???
Thanks Again...
- DaneAApr 07, 2016NETGEAR Employee Retired
Hi Blitz2016,
For the HyperTerminal program, you may use PuTTy. You may download PuTTy here.
Have you tried to select "13 - Password Recovery Procedure?" Kindly post screenshots or images that shows the output on your end as you follow the procedures on the link I have provided.
Also, you may want to open an online case with NETGEAR Support for further assistance. Kindly state your concern and what procedure(s) you have done so far.
DaneA
- Blitz2016Apr 09, 2016Aspirant
Dane,
Even though PuTTY has scant serial settings it does work on the router if you know the correct COM port and manually set speed to 115200.
Got the option 13 taken care of (admin passwords) and thanks again.
For grins I tried option 17 -- Start Diagnostics Application -- and I cannot find such password after searching a number of areas on the Netgear sites and others. My passwords do not work either. So I am beginning to wonder if #17 even is implemented.
Thanks...
