gavinnewell
Jan 25, 2019Tutor
NETGEAR NMS300 Software
A quick question if may. I have installed NMS300 on a virtual server on my local network. How do I access the NMS300 login page from a client computer?
Any advice or guidance would be appreciated...
- Feb 04, 2019
All sorted now. The issue was the firewall on the Virtual Machine. Allowed the NMS software through and it works fine now. A simple mistake.
schumaku
Jan 25, 2019Guru - Experienced User
Check e.g. NMS300 User Manual, p. 18, Get Started,
Log In to the Application
To select your language and log in to the application:
1. Open a browser and connect to the application through the static IP address of the
NMS300 server.
• To connect to the application from the same NMS300 server on which you installed
the application, enter the URL http://localhost:8080.
If you entered a different port number for the NMS300 server during the application
installation, replace 8080 in this URL with the port number that you provided during
installation.
• To connect to the application from a remote computer, replace localhost with the IP
address of the NMS300 server. For example, enter http://203.0.113.56:8080, in
which 203.0.113.56 is the IP address of the NMS300 server and 8080 is the port
number for the NMS300 server.
gavinnewell
Jan 25, 2019Tutor
Thanks for the reply. I'm needing to connect from a remote computer and have tried what you posted below. But sadly it does not connect and displays the following...
