gavinnewell
Jan 25, 2019Tutor
NETGEAR NMS300 Software
A quick question if may. I have installed NMS300 on a virtual server on my local network. How do I access the NMS300 login page from a client computer?
Any advice or guidance would be appreciated...
- Feb 04, 2019
All sorted now. The issue was the firewall on the Virtual Machine. Allowed the NMS software through and it works fine now. A simple mistake.
gavinnewell
Jan 29, 2019Tutor
Hi,
I can't seem to locate the manual that your referencing. Would it be possible for you to send me have the link.
gavinnewell
Feb 04, 2019Tutor
