mariz's avatar
mariz
Follower
Oct 05, 2015
netgear prosafe gsm7352s
having problem on netgear prosafe gsm7352s how can i start to access the console?
1 Reply
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello mariz,
    Welcome to the community!
    I understand you want to access the switch by using the console. You can access the CLI by using a direct console connection or through SSH or TelNet connection from a remote management host. For the connection, you have to use a direct connection to the console port. Accessing the system remotely requires an IP address, subnet mask and default gateway. You can set the network configuration manually, or you can configure the system to accept these settings from a BOOTP or DHCP server on your network. Click the following link for details Network Interface Commands, see page 10-4 (NOTE: your system should be running atleast firmware 8.0).
    We also would like to know what issues you are experiencing on the switch.
    I hope that the information I have provided helps you, if you have more questions we'll be happy to assist.
    Thanks,
ProSupport for Business
