JMACJR
Dec 10, 2016Aspirant
Netgear Prosafe plus GS116e Switch problem with accessing NFS server
Whiched out router and now running NAS through my swtch above. All access to the NFS server now is extreme slow response time. All connections to my network come off this switch. Running a Synology ...
XavierLL
Dec 11, 2016NETGEAR Employee Retired
Hi Jmacjr,
Welcome to the community,
As you described the plus switch performance should be the same as a unmanaged switch, so first you should turn off all the features that you are not using and use the monitoring tools that the GS116E has:
- Turned off IGMP snooping ( Page 16 http://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdf)
- Check port statistics ( Page 76 http://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdf) Is there any error in the NAS port or any other device?
- Check Link Speed/ Duplex ( Page 58 http://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdf) Is linked to the correct speed? If not could you update the network drivers on the NAS
In order to identify the problem it will also help if you can do a port mirrroring and capture the packets using a tool like wireshark.
Hope that it helps
Xavier Lleixa Rillo
NETGEAR CBU Product Line Manager
JMACJR
Dec 12, 2016Aspirant
Those done and no problems noted. Bought an unmanaged switch and relized still have same problem so not a problem with this switch. Continuing to try and figure out why the problems with NFS server on my Synology box.
Thanks for the help.
