johnrdonovan1
May 18, 2016Aspirant
Setting up NETGEAR ProSAFE JGS524 w/ Wireless Access Points
Wanted to get some advise from the community regarding my Netgear JGS524 Unmanaged Switch. I am about to set up a home network with the following devises:
Netgear CM600 Router
Netgear ProSAFE JGS524 24 Port Switch
QNAP TS453 Pro NAS
Computers (3)
Amazon Fire (3)
ASUS Wireless Routers - Access Points (3)
HP Wireless Printer
My intention is to connect my router directly to the ProSAFE switch and than connect all of the other devises including my wireless routers to the switch. Is this the right way to go or should I consider a different approach. I would to have access to the NAS and Wireless Printer regardless of what wireless access point my computer logged on to. Any suggestions would be greatly appreciated.
Hi johnrdonovan1,
Kinda missed that, sorry! Yes, it is only a modem so you'll basically need a modem-router combo (gateway - to replace the CM600) or a router. So the setup will be CM600>Router>Switch. The CM600 will not be able to accommodate the IP addressing.
Thanks,
- JohnRoNETGEAR Employee Retired
Hello johnrdonovan1,
Welcome to the community!
This should work fine considering the location of the devices and since the switch is only unmanaged. It would be better though if you will connect some of the devices (probably the ones near the router) to the CM600 router. All in all this setup is great. :)
Let us know if you have more questions.
Thanks,
- johnrdonovan1Aspirant
Thanks JohnRo - I was looking at this again and was wondering if I needed to change on of the ASUS Routers from an access point and place it in between the CM600 and the switch. I was reading more on the CM600 and it looks like it is just a modem. Any thoughts?
Hi johnrdonovan1,
Thanks,
