msohaibayub
Feb 22, 2013Aspirant
Netgear switch Prosafe GSM7328SO not working after Reset
Sir, I am research assistant in university. I have Netgear Prosafe GSM7328SO switch.I was trying to get familiar with its functionality. I connected this switch to my computer with serial cable (t...
msohaibayub
Feb 25, 2013Aspirant
Dear Mizoguchi,
Thanks for your reply. I simply gave reset command on boot menu, is there any way to get switch working? I have searched boot issue on netgear forum. It simply says that 'reset' command revert switch back to its original setting for ip,buadrate etc. But in my case, switch does not working and its Power LED is showing that it is in POST state.
Sohaib Ayub
Sohaib Ayub
June Mizoguchi:
There is some thread on switches boot issues.
If you can not get any to show up in the console at all then you need to call support get RMA the unit
