tuddy
Aug 27, 2015Aspirant
Network setup M4100 Switch and streaming services
Hi guys, my first post here so please go gentle. I have dabbled in the dark arts of IT for many years but am rather inexperienced when it comes to network setups. My hope setup is thus: Modem/...
DaneA
Aug 30, 2015NETGEAR Employee Retired
Hi tuddy,
A few questions below:
a. If you connect both the Apple TV and Sonos directly to the DGND3700v2, are you getting drop outs?
b. Connect the M4100-D12G switch directly to the DGND3700v2. Then, connect both the Apple TV and Sonos directly to the M4100-D12G switch, are you getting drop outs?
c. What is the current firmware version of the M4100-D12G switch and DGND3700v2?
d. If you disable STP on the M4100-D12G switch, are you getting drop outs?
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
Netgear Community Team
- tuddySep 04, 2015Aspirant
Hi Dane,
Many thanks for taking the time to reply, its most appreciated. After reading your questions I realised I should have posted a little more info about the configuration of my network, apologies for that.
I will endeavour to answer your questions as follows:
- Yes - this was my original setup and the drop outs were terrible to the point where I would have to reset the modem all the time with just Sonos working (which started me on the quest of investigating network setups for Sonos, and led to the purchase of a managed switch)
- Yes - as mentioned above I should have explained my configuration in my original post. My current setup has the M4100-D12G connected directly to the DGND3700v2: no other ports on the M4100-D12G are used; every other wired device in the network is connected via the M4100-D12G. With this setup and STP enabled the Sonos works beautifully by itself (i.e. it fixed my original problem), but not long after streaming a movie through apple TV I will start getting drop out in the Sonos.
- M4100-D12G: firmware = 10.0.2.13
- DGND3700v2: firmware = 1.1.00.24
- This is an excellent question, and probably something I should have at least tried. However, all the research I did about Sonos systems suggested STP was required as Sonos uses STP for its mesh network.
- So tonight I have tried disabling STP and guess what??? The drop outs have stopped :smileyhappy: I tested the system just prior to disabling STP and the dropouts were still happening, its been two hours of streaming apple TV and Sonos now and no drop outs :smileyhappy:
- After the first hour of no drop outs I also enabled "Forward BPDU while STP Disabled". Apparently Sonos required BPDU packets to be forwarded to stop network storms: I don't know how to test this, but even with it disabled Sonos appeared to work fine.
The outcome: well I am stoked that the drop outs appear to have stopped: this is great news! And I thank you very much for your ideas, and solution!
Now I am also a very analytical person so I would be keen to understand understand why turning off STP would fix the problem (I did buy a managed switch after all to fix my problems lol). Also is there any way that I can check to what is going on with the network traffic - I would be keen to see the difference between the settings.
Thanks very much for your help.
Cheers,
Tuddy
- tuddySep 05, 2015Aspirant
Looks like I spoke to soon, even with STP disabled I am getting the odd drop out when streaming music and video at the same time :smileysad:
- DaneASep 06, 2015NETGEAR Employee Retired
Hi tuddy,
Based from your answer, since dropouts occurs at the setup described above, it could be a setting on the DGND3700v2 or Sonos that needs to be modified. Check the physical connection as well. Are you using CAT5e or CAT6 ethernet cables?
Does the Sonos device you have works offline? If yes, disconnect the M4100-D12G switch from the DGND3700v2 then connect both the Apple TV and Sonos directly to the M4100-D12G switch then play a movie. Do you observe any dropouts? (Note: Try to enable or disable STP to observe)
DaneA
- tuddySep 27, 2015AspirantHi Dane, Thanks for your reply mate. I'm running Cat5e cable through the house but I was having the same problem when I was running short patch cables in my previous setup, and come to think of it I was having the problem when the Apple TV was connected via wifi. Unfortunately the Apple TV and the sonos both require an Internet connection to operate (as they are both accessing streaming service) so I can't test your suggestion of trying the direct connection to the switch. I have been watching the sonos controller when the dropouts occur and it displays a message saying it is unable to maintain a sufficient buffer speed. It seems to me that the Apple TV is somehow hogging all the bandwidth. I've read the QOS help but I don't really understand how to implement it properly. Do you think this may help my problem? Cheers Tuddy
