virtualnobody
May 25, 2016Aspirant
NMS300 switch config backup M4300
Hi Community, is it possible to backup the switch configuration from M4300-Series in NMS300? Got the latest release of NMS300 installed (1.5.0.14), desired switch is listed 'version informati...
- Jul 08, 2016
Seems to be an issue within NMS300 and will be fixed in next release.
Thanks!
DaneA
May 25, 2016NETGEAR Employee Retired
Hi virtualnobody,
Welcome to the community! :)
I'm afraid to inform you that the M4300 series switches are not yet supported by the NMS300. On the latest NMS300 software release v1.5.0.14, only the XS708T and XS716T switches have been added on the supported switches of NMS300. You may check the release notes of the NMS300 software release v1.5.0.14 here.
I suggest you to post this as a new idea at the Idea Exchange Board for Business here. Be reminded that adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
DaneA
NETGEAR Community Team
virtualnobody
May 28, 2016Aspirant
Hi DaneA,
thanks for you suggestion, I will do so.
Best regards.
- mdgm-ntgrMay 30, 2016NETGEAR Employee Retired
Our QA team has re-tested on NMS300v1.5.0.14 with M4300(12.0.0.15 and 12.0.0.1), and it works well in our lab.
You may wish to open a support case with our support team so they can look into this with you. Let me know your case number.- virtualnobodyMay 30, 2016Aspirant
Have created a new support case, ticket no is #26937988.
Thanks and best regards.
Thanks
