virtualnobody
May 25, 2016Aspirant
NMS300 switch config backup M4300
Hi Community, is it possible to backup the switch configuration from M4300-Series in NMS300? Got the latest release of NMS300 installed (1.5.0.14), desired switch is listed 'version informati...
- Jul 08, 2016
Seems to be an issue within NMS300 and will be fixed in next release.
Thanks!
virtualnobody
May 28, 2016Aspirant
Hi DaneA,
thanks for you suggestion, I will do so.
Best regards.
mdgm-ntgr
May 30, 2016NETGEAR Employee Retired
Our QA team has re-tested on NMS300v1.5.0.14 with M4300(12.0.0.15 and 12.0.0.1), and it works well in our lab.
You may wish to open a support case with our support team so they can look into this with you. Let me know your case number.
- virtualnobodyMay 30, 2016Aspirant
Have created a new support case, ticket no is #26937988.
Thanks and best regards.
- mdgm-ntgrMay 30, 2016NETGEAR Employee Retired
Thanks
- virtualnobodyJul 08, 2016Aspirant
Thanks!
