virtualnobody
May 25, 2016Aspirant
NMS300 switch config backup M4300
Hi Community, is it possible to backup the switch configuration from M4300-Series in NMS300? Got the latest release of NMS300 installed (1.5.0.14), desired switch is listed 'version informati...
- Jul 08, 2016
Seems to be an issue within NMS300 and will be fixed in next release.
Thanks!
Retired_Member
May 30, 2016Could you check if you get the TFTP server up on “Resources->NMS Server details”?
virtualnobody
May 30, 2016Aspirant
Yes, TFTP server is Up.
Since the logfile shows some progress it must be interrupted by something.
