Michal21
Oct 19, 2021Initiate
NTP Client GS752TS and GS748Tv4H2 Port
Hello, I have a question and a Problem Switch GS748Tv4H2 asks my NTP server after Port 1031 or 1025 despite defined Port 123 On the other hand, the Switch GS752TS asks for port 123 without any probl...
Michal21
Oct 20, 2021Initiate
Well, Switches send an inquiry from Port 1025 and 1031 and not from Port 123 like the other Switches. Therefore, I would like to ask if I can set this switch to make a query from port 123 and not from 1031 or 1025.
schumaku
Oct 20, 2021Guru - Experienced User
Different eg. for DNS XFER there is not requirement for having the source port on 123/udp for SNTP isn't it?
Said that, you can't change the switch IP stack and the SNTP client config for a different source port.
