cookiesmonster's avatar
Aug 26, 2016
Open managment website GS108T
Hi,
I have 2 GS108T managed switches. Because i lost the password i found a Kb to set the switch to factory default.
After the reset i can set a new password with the discovery tool but i cannot open the website.
The IP adres is correct and the switch is responding to ping.
What can i do?
Regards
Thomas
  • Hi,
    I did a second factory reset of both switches.
    They are both working fine now.
    Can't explain why but i'm happy with the result.
    Regards and thank you for your assistance.
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hi cookiesmonster,
    Welcome to the community!
    What is the error message you are getting? Are opening the web-ui using the utility or manually typing the address on a browser?
    Thanks,
  • DaneA's avatar
    DaneA
    Hi cookiesmonster,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your concern or if you need further assistance.  The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
    • Hi,
      • DaneA's avatar
        DaneA
        Hi cookiesmonster,
        I'm glad to know that both switches are now working fine. :)  I appreciate that you've shared the solution you did to resolve the problem.
        Feel free to post your future concerns here in the community.
        Cheers,
        DaneA
ProSupport for Business
