APurk
Sep 12, 2016Tutor
PBR Policy Based Routing using Managed Switch
I am no expert with networks, but I am wondering if anyone has had any experience with PBR (Policy Based Routing) using Netgear Managed Switches. More specifically I am wanting to define the onward ...
LaurentMa
Feb 09, 2017NETGEAR Expert
Hi APurk,
M5300 models don't support PBR. Datasheet and other brochures hopefully indicate that.
Instead, Technical documentation is cross platform for Fully Managed Switches, based on Software release / branch number, so 10x, 11x etc..
To date, only M6100 Chassis and newer M4300 Stackable L3 series (both 1G models and 10G models) offer PBR. You can visit www.netgear.com/managed
PBR configuration is CLI mode only, this is one of the only few features we don't show in Web interface (GUI). You can refer to CLI manual indicated above in DaneA response.
I hope this helps!
I hope this helps!
