ivanelectrocoal
Mar 13, 2018Aspirant
PoE issues M4300-52G-PoE+
Hi, i have several M4300-52G-PoE+ switches with PoE issues. IP cams and ubiquiti APs lost power from switch and shutdown soon after switch turn on, for example: AP on port 1 goes down cause switch t...
Retired_Member
Mar 14, 2018
Welcome to the community!
According to your description, both IP cams and ubiquiti APs can work normal with PoE powered on port2, but cannot work stably on port1, right?
For further analysis, Could you please show detailed PoE info for port1 and port2, just with command as below:
show poe port configuration x/x/x(port1/2 number)
show poe port info x/x/x(port1/2 number)
Hope it helps!
EricZ
NETGEAR employee
- ivanelectrocoalMar 15, 2018Aspirant
Hi, here is output from console
(M4300-52G-PoE+) >en(M4300-52G-PoE+) #show poe port configuration 1/0/1
Admin Power Power Limit High Power Detection Timer Schedule
Intf Mode Priority Limit Type Mode Type
(mW)
1/0/1 Enable Low N/A Class Based Dot3at ieee None(M4300-52G-PoE+) #show poe port info 1/0/1
High Max Output Output
Intf Power Power Class Power Current Voltage Status Fault
(mW) (mW) (mA) (V) Status
1/0/1 Yes 32000 Unknown 0 0 0 Searching No Error
Overload Counter .............................. 0
Short Counter ................................. 0
Power Denied Counter .......................... 0
Absent Counter ................................ 0
Invalid Signature Counter ..................... 0(M4300-52G-PoE+) #show poe port configuration 1/0/2
(mW)
1/0/2 Enable Low N/A Class Based Dot3at ieee None(M4300-52G-PoE+) #show poe port info 1/0/2
1/0/2 Yes 32000 4 2800 52 55 Delivering Power No Error
Invalid Signature Counter ..................... 0- Retired_MemberMar 15, 2018
Hi ivanelectrocoal,
Looks like the configuration is correct.
For further analysis,Could you please provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439- atianApr 03, 2018Aspirant
Could you check the following step by step?
1) remove all of PDs and connect the port from 1/0/1 to 1/0/8 one by one and see if only the port1 doesn't provide the power.
2) If 1/0/1 to 1/0/8 can provide the power if there is only one PD to the switch, move the existing PD to the port 1/0/1, then connect another PD to the 1/0/2, and see if the port 1/0/2 can provide the power.
3) if port 1/0/2 cannot provide the power on step 2, move the PD from 1/0/2 to the port 1/0/5 and see if port 1/0/5 can provide the power.
we saw one issue similar to this before, but please try the step 1 to 3 first, we can see if they are the same issue.
