ivanelectrocoal
Mar 13, 2018Aspirant
PoE issues M4300-52G-PoE+
Hi, i have several M4300-52G-PoE+ switches with PoE issues. IP cams and ubiquiti APs lost power from switch and shutdown soon after switch turn on, for example: AP on port 1 goes down cause switch t...
ivanelectrocoal
Mar 15, 2018Aspirant
Hi, here is output from console
(M4300-52G-PoE+) >en
(M4300-52G-PoE+) #show poe port configuration 1/0/1
Admin Power Power Limit High Power Detection Timer Schedule
Intf Mode Priority Limit Type Mode Type
(mW)
1/0/1 Enable Low N/A Class Based Dot3at ieee None
(M4300-52G-PoE+) #show poe port info 1/0/1
High Max Output Output
Intf Power Power Class Power Current Voltage Status Fault
(mW) (mW) (mA) (V) Status
1/0/1 Yes 32000 Unknown 0 0 0 Searching No Error
Overload Counter .............................. 0
Short Counter ................................. 0
Power Denied Counter .......................... 0
Absent Counter ................................ 0
Invalid Signature Counter ..................... 0
(M4300-52G-PoE+) #show poe port configuration 1/0/2
(mW)
1/0/2 Enable Low N/A Class Based Dot3at ieee None
(M4300-52G-PoE+) #show poe port info 1/0/2
1/0/2 Yes 32000 4 2800 52 55 Delivering Power No Error
Retired_Member
Mar 15, 2018Hi ivanelectrocoal,
Looks like the configuration is correct.
For further analysis,Could you please provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
- atianApr 03, 2018Aspirant
Could you check the following step by step?
1) remove all of PDs and connect the port from 1/0/1 to 1/0/8 one by one and see if only the port1 doesn't provide the power.
2) If 1/0/1 to 1/0/8 can provide the power if there is only one PD to the switch, move the existing PD to the port 1/0/1, then connect another PD to the 1/0/2, and see if the port 1/0/2 can provide the power.
3) if port 1/0/2 cannot provide the power on step 2, move the PD from 1/0/2 to the port 1/0/5 and see if port 1/0/5 can provide the power.
we saw one issue similar to this before, but please try the step 1 to 3 first, we can see if they are the same issue.
