beakerton's avatar
beakerton
Follower
Jul 28, 2022
PoE Measurement Accuracy
Hi!  I'm looking at using a managed 802.11bt PoE switch (specifically GSM4212UX) and would like to use it to monitor the voltage/current/power delivered to each PD.  I know that I can retrieve the voltage/current for each interface out of the management console.  What is the level of accuracy/resolution that these measurement provide?
Thank you!
ProSupport for Business
