ChristianB
Jan 26, 2018Aspirant
PoE setup on M4300-28G-PoE+
Hi all! We experience an issue with a brand-new M4300 series PoE+ switch. There is no power available on the ports. System > PoE > Basic > PoE Configuration Power Status sais OFF, and it is ...
- Feb 22, 2018
the replacement has arrived. I've installed the system, and it works perfectly.
Thanks for the assistance!
ChristianB
schumaku
Jan 26, 2018Guru - Experienced User
wrote:There is no power available on the ports.
...Or does it switch to ON automatically when a PoE device is detected?
How do you know there is no power available? Plug one and you will see...
Standards compliant PoE power is not always "on" on PoE ports - on plugging, there is a handshake between the PO and the PD.
