ChristianB
Jan 26, 2018Aspirant
PoE setup on M4300-28G-PoE+
Hi all! We experience an issue with a brand-new M4300 series PoE+ switch. There is no power available on the ports. System > PoE > Basic > PoE Configuration Power Status sais OFF, and it is ...
- Feb 22, 2018
the replacement has arrived. I've installed the system, and it works perfectly.
Thanks for the assistance!
ChristianB
DaneA
Feb 13, 2018NETGEAR Employee Retired
Thanks for the feedback.
I suggest you to update the firmware of the M4300-28G-PoE+ switch to v12.0.2.20. You can download firmware v12.0.2.20 here. Be reminded to perform a factory reset on the M4300-28G-PoE+ switch after upgrading the firmware then reconfigure the settings from scratch. Then, check if the same problem occurs.
DaneA
NETGEAR Community Team
ChristianB
Feb 15, 2018Aspirant
Hi DaneA,
thanks for your help. Meanwhile I have updated the firmware, contacted phone support, and they came to the conclusion to replace the device.
They were not able to fix the problem. We have several M4300 units, and only one is making trouble, regardless of the configuration and the firmware.
Thanks for your help, I think that this device is broken and replacement is on the way.
Cheers,
ChristianB
