ChristianB
Jan 26, 2018Aspirant
PoE setup on M4300-28G-PoE+
Hi all! We experience an issue with a brand-new M4300 series PoE+ switch. There is no power available on the ports. System > PoE > Basic > PoE Configuration Power Status sais OFF, and it is ...
- Feb 22, 2018
the replacement has arrived. I've installed the system, and it works perfectly.
Thanks for the assistance!
ChristianB
DaneA
Feb 19, 2018NETGEAR Employee Retired
Thanks for the update. Let us know if you already received the replacement unit and check if its working fine.
DaneA
NETGEAR Community Team
ChristianB
Feb 22, 2018Aspirant
ChristianB
