Elsydeon's avatar
Elsydeon
POE++ switch with MAC filtering
I am working with a client to install an outdoor camera system.
One of the possible security issues is if the camera were removed, it's ethernet connection could be used to gain access to the network.
As such, using a cheap managed POE switch with MAC filtering capability would be the ideal solution.
I was thinking of the MS108EUP, since it is a power injector that identifies as a switch, but nothing in the manual mentions MAC filtering.
What is the cheapest POE++ (for future power needs) switch that does MAC filtering.?
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello Elsydeon,
    And welcome to the NETGEAR Community! 🙂
    Indeed you are correct, nothing was mentioned about MAC filtering for MS108EUP. So for your requirements the next device I would suggest you buy is MS510TXUP, although this device has no MAC filtering mentioned also on the manual but has port security that you can setup for protection. You may check page 375-379 from the link below on how to configure this.
    https://www.downloads.netgear.com/files/GDC/MS510TXM/MS510TXM_MS510TXUP_UM_EN.pdf?_ga=2.66143534.1405618831.1678466476-761792600.1608443885.
    Have a lovely day,
    erwin
    NETGEAR Team
  • ErwinL's avatar
    ErwinL
    NETGEAR Moderator
    Hello Elsydeon,
    Did I answer your question? In this case could you give us feedback on the situation and accept my post
    as a solution to make it more visible to other users?
    Thanks in advance!
    Have a lovely day,
    Erwin
    Netgear Team
ProSupport for Business
