EnriqueT
Aug 24, 2016Aspirant
Port 9 and 10 disable on GS110TP (firmware version 5.4.2.19)
Dear Netgear staff, I have noticed that when I disable port 9 on my switch GS110TP then the port 10 comes down. However, when I disable port10 then the port9 remains UP which should be the normal...
JohnRo
Aug 25, 2016NETGEAR Employee Retired
Hello EnriqueT,
Welcome to the community!
Sorry to hear about this issue. I have looked at our list of reported bugs but did not see anything related to the one you are having. Also, I have checked the release notes for each firmware mentioned and I found nothing regarding this. I suggest opening a Support Ticket for this issue to be filed. For the meantime, I'll try to get the attention of the engineers and see if they have seen the issue.
Thanks,
- EnriqueTAug 25, 2016Aspirant
Hello JohnRo,
We have many switches with the same issue. Do you have a specific e-mail address in order to send more details.
Thanks in advance
Enrique
- JohnRoFeb 02, 2017NETGEAR Employee Retired
Hi EnriqueT,
I would just like to follow up if you still need assistance with this issue?
Thanks,
- JohnRoFeb 06, 2017NETGEAR Employee Retired
Hi EnriqueT,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
