EnriqueT
Aug 24, 2016Aspirant
Port 9 and 10 disable on GS110TP (firmware version 5.4.2.19)
Dear Netgear staff, I have noticed that when I disable port 9 on my switch GS110TP then the port 10 comes down. However, when I disable port10 then the port9 remains UP which should be the normal...
EnriqueT
Aug 25, 2016Aspirant
Hello JohnRo,
We have many switches with the same issue. Do you have a specific e-mail address in order to send more details.
Thanks in advance
Enrique
JohnRo
Feb 02, 2017NETGEAR Employee Retired
Hi EnriqueT,
I would just like to follow up if you still need assistance with this issue?
Thanks,
