joeyang
Jul 30, 2019Aspirant
Problem Configuring VLAN routing OSPF M4300-12X12F FW 12.0.4.8
Hi, We just bought M4300-12X12F for a storage project. Attached is the network diagram for reference. I need to create a VLAN 172. I have configured the Netgear to communicated with Cisco Nexus 7...
Retired_Member
Aug 09, 2019Hi joeyang
Welcome to Community!
Yes, your VLAN 172 status is Down.
Could you please check if there is at least one up port under VLAN 172?
And for more detailed info, please run below command on the switch:
show vlan 172 | include Inc
show port all | include Up
show spanning-tree mst port summary 0 active
EricZ
- joeyangAug 10, 2019Aspirant
Hello Retired_Member
I am not very familiar with CLI commands. We did the configuration mostly on the GUI interface. It is so weird that we repeated the process following the guide from below link and it never worked. When we are about to give up, and tried doing the same process the last time, some how the vlan suddenly became active and the network is running fine. We will keep observing this and will keep you guys updated.
Thanks
- Retired_MemberAug 14, 2019
