FSIT
Jul 19, 2011Aspirant
Prosafe GSM7248 LAGs & LACP
I'm looking into purchasing a pair of Prosafe GSM7248 switches 2nd hand and was wondering if anyone knew how many LAGs were supported, and if the switch supports LACP. I looked through a manual that I found online, but didn't see anything specific in regards to this.
S/N of the switches: 1DU3993U000C6 and 1DU38B3900006
- GlitchedAspirantIf I recall correctly you should be able to do up to 8 LAGs. I'm 100% confident that it supports LACP.
- FSITAspirantNow... How do we reset the password on these things? Tried the defaults and they don't work. Tried "Erase current configuration" and even made the mistake of "Erase permanent storage" and still unable to log in (even after flashing new firmware after the previous mistake). The "EmergencyPasswordRecovery" trick doesn't work.
- FSITAspirantAwesome, my whole reply disappeared when I clicked "Post Quick Reply". How does one reset the password on these devices?
- FSITAspirantNever mind my last post, I figured it out.
- ZCPM3Aspirant
FSIT wrote: Now... How do we reset the password on these things? Tried the defaults and they don't work. Tried "Erase current configuration" and even made the mistake of "Erase permanent storage" and still unable to log in (even after flashing new firmware after the previous mistake).
FSIT, can you walk me through how you got your switch back up and operational? I just made the same mistakes you did and my console is all messed up now. :( - FSITAspirant
ZCPM3 wrote: FSIT, can you walk me through how you got your switch back up and operational? I just made the same mistakes you did and my console is all messed up now. :(
I would, but it requires re-flashing the newest firmware to the switches. Unfortunately there's a problem with the newest firmware, where it WIPES the switches MAC addresses! So now I can access both switches, but they don't work correctly and you can't have more than one on the network at a time (because it defaults to the firmwares IP of 00:00:01:02:03)!
I have a support ticket open with Netgear now, they're working on fixing this problem, but for now I'm using a GSM7224 and four "dumb" switches just so our network kinda works. - ZCPM3Aspirant
FSIT wrote: I would, but it requires re-flashing the newest firmware to the switches. Unfortunately there's a problem with the newest firmware, where it WIPES the switches MAC addresses! So now I can access both switches, but they don't work correctly and you can't have more than one on the network at a time (because it defaults to the firmwares IP of 00:00:01:02:03)!
Well I can't even get to the admin menu in the console so you're further along than me. I may just open up an RMA request and put that lifetime warranty to work! - FSITAspirant
ZCPM3 wrote: FSIT, can you walk me through how you got your switch back up and operational? I just made the same mistakes you did and my console is all messed up now. :( ZCPM3 wrote: Well I can't even get to the admin menu in the console so you're further along than me. I may just open up an RMA request and put that lifetime warranty to work!
I wouldn't rely on that "lifetime warranty" too much. I registered all of my Netgear managed switches on the support website so I can be notified of firmware upgrades and what not, and they all show that the warranty has expired! - ZCPM3Aspirant
FSIT wrote: I wouldn't rely on that "lifetime warranty" too much. I registered all of my Netgear managed switches on the support website so I can be notified of firmware upgrades and what not, and they all show that the warranty has expired!
Mine shows up with hardware warranty active. Fingers crossed Netgear will actually honor it. - GlitchedAspirantAs long as you have a purchase date past May 1st, 2007 then all prosafe products have a lifetime warranty. If the support site is showing the warranty expired then its just a glitch or bug in the interface. When you cleared the permanent storage, you didn't only erase the firmware, but all vital product data. The problem you're experiencing with the MAC address being wiped out wasn't done by the firmware.(I have several of these switches updated weekly and don't have the MAC wiped out). Best thing to do is to open a support case at my.netgear.com and see if engineering can do anything or if they will issue an RMA. Also what password are you trying? The default password for these switches are blank.
