waynefury
Jul 14, 2017Aspirant
Prosafe M4100-50G-POE+ failed after update
Hello I have a M4100-50G-POE+ which has failed after a firmware update, the power led is blinking orange. Most manuals says it has failed POST, one of them says the power supply has failed - is...
JohnC_V
Jul 15, 2017NETGEAR Employee Retired
Hi waynefury,
Welcome to the community!
As I checked the initialization process of the switch that it can't load the flash2.stk1. This is a bad firmware upgrade result that it cannot load the image from the flash. May I know what firmware version are you trying to upload? Please make sure that your are uploading the correct firmware for your M4100 device. You may still recover the switch by reflashing the switch via CLI using XModem.
Please refer to this link. Hope this helps.
waynefury
Jul 16, 2017Aspirant
Hi JohnCarloV
Thank you for your reply and the link to the recovery procedure.
Looking at my CLI output it appears that the switch has no access to its flash memory (so I never get to "Starting program at 0xXXXXXXXX" and cannot stop the boot sequence and enter the boot menu in the link provided).
It all seems to go astray at the line starting "Loading:"
The example in your link continues with "STK image is 12324100 bytes, CRC 0xFC98 3605504 bytes"
The switch I am working on returns " Could not load flash2.stk1:: Error"
Prior to that there are also "not enough PCI mem space" errors (lines starting PCI)
However I can get to the CFE> prompt by pressing Ctrl-C, is there another recovery procedure I can use?
Thank you
Wayne
- waynefuryJul 16, 2017Aspirant
Hi again JohnCarloV
Is this a procedure I can use?:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Thankyou
Wayne
- JohnC_VJul 18, 2017NETGEAR Employee Retired
My apologies but that procedure will only work on our firewalls. Have you tried pressing and holding "q" once it boots up?
- waynefuryJul 19, 2017Aspirant
Hi JohnCarloV
Thank you for your reply, as I said above I cannot get into the CLI menu (by pressing and holding q), please see Appendix 1 below for the console output.
Thanks also for letting me know the link supplied was only for your routers. Could you please let me know if there is a recovery procedure for your switches? (when the Netgear CLI is inaccessible) If not, I will return the switch under warranty - it is only 1 month old and its POE did not function correctly. Updating the firmware, as recommended by Netgear support left the switch in this un-usable state.
As I also pointed out above, I can get into the CFE console by pressing Control-C. I am guessing you are using Broadcom hardware in your switches and this is their firmware interface/bootloader. Please let me know if I can use this to reload the netgear firmware. If not, I will return the swiitch under warranty.
Thank you
Wayne
Appendix 1 (console output of not being able to access the CLI menu by pressing and holding the q key):
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqInitializing Arena.
Initializing PCI. [normal]
qPCI[0]: Initializing host
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqPCI[1]: Initializing host
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqPCI[1] bus 0 slot 0/1: (24) not eno ugh PCIq mem space (134217728 requested)
PCI[1] bus 0 slot 0/0: (24) not enough PCI mem space (134217728 requested)
Initializing Devices.qqqqqqqqqqqLoader:stk Filesys:raw Dev:flash2.stk2 File: Options:(null)
Loading: qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq qqqqqqqqqqqqqqqqqqqCould not load flash2.stk2:: Error
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqLoader:stk Filesys:raw Dev:flash2.stk1 File: Optio ns:(null)
Loading: qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq qqqqqqqqqqqqqqqqqqqCould not load flash2.stk1:: Error
**Exception 32: EPC=87E8A6D8, Cause=4000001C (BusErrD )
RA=87E8A6D4, VAddr=A51F3ED40 ($ 0) = 00000000 AT ($ 1) = A0000000
v0 ($ 2) = 00000001 v1 ($ 3) = 87EFD8F8
a0 ($ 4) = A8000148 a1 ($ 5) q= 00000148
a2 ($ 6) = 87FFF388 a3 ($ 7) = 000000A0
t0 ($ 8) = 00000007 t1 ($ 9) = 00000008
t2 ($10) = 00000001 t3 ($11) = 00000000
t4 ($12) = 30000000 t5 ($13) = 00000000
t6 ($14) = 00000000 t7 ($15) = 00000000
s0 ($16) = 87FFF388 s1 ($17) = 87F00E10
s2 ($18) = 00000148 s3 ($19) = 87FFF388
s4 ($20) =q 00000000 s5 ($21) = 00000000
s6 ($22) = 000009E0 s7 ($23) = 87E5F000
t8 ($24) = 3011FFFE t9 ($25) = 87E9B238
k0 ($26) = 87EF8E80 k1 ($27) = 87FFF30C
gp ($28) = 87EF8E80 sp ($29) = 87FFF320
fp ($30) = E825F000 ra ($31) = 87E8A6D4qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
Initializing Arena.
