zsmith16
Sep 07, 2018Follower
ProSafe Manage Switch Power Bump When Unplugging Second Power Supply
Hello,
I am using multiple Stacks of M4300-52G-PoE+ ProSAFE 48-port 1G PoE+ and 2-port 10GBASE-T and 2-port 10G SFP+ (was unable to find the model in the drop down above).
We run the Stac...
DaneA
Sep 10, 2018NETGEAR Employee Retired
Hi zsmith16,
Welcome to the community! :)
Since the current firmware version is on v12.0.4.8, I suggest you to upgrade the firmware to the latest version in a ladderized manner. First, upgrade the firmware from v12.0.4.8 to v12.0.4.9. Then, from v12.0.4.9 to v12.0.6.6 until you reach the latest version which is v12.0.7.7. Be sure to perform a factory reset on the M4300-52G-PoE+ switch after upgrading the firmware to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, observe if the same problem will occur.
You can download the firmware versions for the M4300-52G-PoE+ switch here.
DaneA
NETGEAR Community Team
