Demi_California
Jan 10, 2017Follower
M4300-12X12F 24-Port Managed Switch 10G link fails to come up with Intel SFP PN: FTLX8571D3BCVIT1
When Intel SFP PN: FTLX8571D3BCVIT is used inside M4300-12X12F 24-Port Managed Switch the 10G link fails to come up, an only way to get this link up is to go into switch configuration and make a manu...
sark
Mar 07, 2017Aspirant
I am interested in buying this switch, and have a DELL R510 server with a dual port INTEL X520-DA2 card, which uses a passive copper coax direct attached cable (no SFP module required for the X520).
Zebibyte
Mar 08, 2017Aspirant
Yes, the latest firmware has helped with the Intel SFPs, but I'm not sure if they would work with a direct attached cable or not. That introduces another SFP+ that Netgear would have to make work. I'm not sure if they have any DAC certified or approved yet.
- sarkMar 09, 2017Aspirant
Great thanks. So I will need to buy two LC compatible modules, one for the X520 and one for the 12x12. Any suggestions?
- ZebibyteMar 09, 2017Aspirant
Compatible modules on page 23/24 here http://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf?cid=wmt_netgear_organic&cid=wmt_netgear_organic
I was hoping for a non-$300+ option.
