MarkusKern
Dec 20, 2016Tutor
M4300 Hard reset to Factory Defaults
We bought a bunch of switches M4300-28G-PoE+. One of them does not connect to the DHCP server on its network side even its set to DHCP client. To overcome the problem I applied a soft reset through t...
- Dec 25, 2016
You're welcome. :) I'm glad to know that you have figured it out and the problem is now solved.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Happy Holidays! :)
Cheers,
DaneA
NETGEAR Community Team
