klat0n
Apr 05, 2017Aspirant
SNTP KISS IRIG
I do not understand why I am getting this KoD. I did not recieve this KoD packet with the older firmware. M5300-28G-POE+ ProSafe 24-port Gigabit L2+ PoE+ with 10 Gigabit Stacking, 11.0....
DaneA
Apr 06, 2017NETGEAR Employee Retired
Hi klat0n,
Kindly answer the questions below:
a. Have you tried to factory reset the M5300-28G-POE+ switch then reconfigure it from scratch?
b. What device is 192.168.1.1? Have you tried to disconnect the M5300-28G-POE+ switch from this device and check if same error will show on the logs?
c. How is everything connected? It would be best to post a diagram of your detailed network setup.
I look forward to your response.
DaneA
NETGEAR Community Team
klat0n
Apr 06, 2017Aspirant
Regarding your question "a." This is not an option because all of the switches that are having this problem are in production.
Question "b." This is a NTP server where all of our devices get is time stamp from. I have tried rebooting and disconnecting the NTP server and the results are the same.
Everything is connected by either fiber or copper in a "star" configuration. the NTP server is connected by copper on one leg of the STAR. A map should not be necessary.
