ncnaveen_arasu
Apr 12, 2016Aspirant
Regarding OID for Netgear switch model GSM7248V2
HI Team, Presently we have many prosafe switch model GSM7248V2 runnning in our environment. So we would like to include these switches in Services monitoring such as CPU,Memory,Temperature, stat...
ncnaveen_arasu
Apr 13, 2016Aspirant
Hi DaneA
Thanks for the information.
I have gone through the link you have shared, which was routed me to Netgear support portal.
I could not able to find the switch model GS105Ev2 under switch category.
Is it out of support ?
How can we get the OID/MIB file for the same.
Thanks
Naveen
ncnaveen_arasu
Hi DaneA
Sorry.. i found the product in product list under web managed device. But do not have the info about mib and OID files.
Can you help.
Thanks
Naveen
- DaneAApr 14, 2016NETGEAR Employee Retired
Hi ncnaveen_arasu,
For the MIB and OID files for the GS105Ev2, I advise you to open an online case with NETGEAR Support. Kindly inquire for the MIB and OID files you needed for the GS105Ev2.
DaneA
NETGEAR Community Team
- ncnaveen_arasuApr 14, 2016Aspirant
Hi Dane,
Thanks for the assistance and support.
Naveen
- DaneAApr 17, 2016NETGEAR Employee Retired
Hi ncnaveen_arasu,
You're welcome! :)
If ever your concern is now resolved, we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!Cheers,DaneA
