fxyoung
Aug 03, 2016Follower
remote management of smart switches
I would like to know if these switches can be controlled remotely. I would like to deploy them in remote oficesf and avoid travel to change setGS`08Ttings
- JohnRoNETGEAR Employee Retired
Hello fxyoung,
Welcome to the community!
Yes, you can manage them remotely. You'll have to setup port forwarding on your router to achieve this. First, assign a static IP address on the switch, and forward HTTPS to the IP address you have assigned. A certificate is required to achieve this since this is very secured. Please see page 157 of the User Manual.
Let us know if you have more questions.
Thanks,
- omicron_persei8LuminaryIt sounds like a very bad idea to me. Switches are by definition not "Internet-proof". It could be very dangerous to expose the GUI of your LAN switch and therefore to expose your LAN to the Internet this way. Whoever succeed to gain access to your switch may have access to your entire network. I would strongly advise you to use a VPN, not port forwarding (even with high port number and strong password).
