JohBo's avatar
JohBo
Request STP with Wireshark
Hi everybody !
I come to put in use my switch M4300 with the protocol STP, when I capture the trames with wireshark, there are a lot of trames STP and I would like to know if it's ok ?
Thank you so much for you help me.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi JohBo,
    Welcome to our community! :)
    Yes, definitely. As long as the STP works, it will provide so much information if you do have redundancy in your connection.
  • JohnC_V's avatar
    JohnC_V
    JohBo,
    I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
    • JohBo's avatar
      JohBo
      Hi JohnC_V,
      Sorry for the late and thank you for your help, I think that's good for my question with STP packets, when I analysed with wireshark during 6 mn, I had 616 STP packets/1004 packets.
      Each STP packets had a size 480 bits that is small with a time of 2s, however, I have 2 different destinations, the first is Spanning-Tree (for bridges) and the second is PVST+, this is normal ?
      Thank you so much for your help.
ProSupport for Business
