Electriceyeguy
Jun 19, 2012Aspirant
Reset password on GS748TPS?
Hello All- Have 4 of these switches (2 in each bldg& stacked via HDMI) connected by fiber. I had a 8 char PW set on the switch and decided to change it today so our security consultant could acces...
jmizoguchi
Dec 20, 2012Virtuoso
Forum is user to user basis not sure why you waited 6month for help
You need to call support directly at my.netgear.com or make support call.
These smart switches does not have console options so you are "very" limited to how you can gain access.
You should have warranty so deal with support and possible to get RMA exchange.
