daveoneal
Sep 20, 2016Aspirant
Service Port routable on managed switch ?
Is the Service Port or Out of Band port connected via ethernet routable? I have our correct subnet and default gateway setup and can't ping past the default gateway (which is a cisco router). I can...
DaneA
Sep 21, 2016NETGEAR Employee Retired
Hi daveoneal,
Welcome to the community! :)
What I know about Out-of-Band connectivity is that you will need to use the console port to connect the switch to a terminal desktop system running terminal emulation software.
What is the model of the NETGEAR switch you have?
DaneA
NETGEAR Community Team
