ManuBernat's avatar
ManuBernat
Follower
May 13, 2016
Setup a stack between distant switches
Hello,
I currently have three switches GSM7352S stacked together with AX742 kits.
I need to set up two more switches (same model) in another room.
I would like to connect all the switches to create a unique stack and I am not sure of the kits needed.
Here is a schema of what I want.
Do you know if it is correct or if there is another (simpler) solution.
Thank you for your help.
[AX742][GSM7352S][AX745]--------(remote approx. 60m.)----------[AX745][GSM7352S][AX742]
[AX742][GSM7352S]                                                     [GSM7352S][AX742]
[AX742][GSM7352S]
    (stack part 1)                                                  (stack part 2)
  • Hi ManuBernat,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello ManuBernat,
    Welcome to the community!
    The setup looks good already, I don't think I can recommend a better one. But before you go with this, please see the FAQ for the AX745 (click here).
    Let us know if you have more questions.
    Thanks,
  • JohnRo's avatar
    JohnRo
    Hi ManuBernat,
    Thanks,
ProSupport for Business
