ManuBernat
May 13, 2016Follower
Setup a stack between distant switches
Hello, I currently have three switches GSM7352S stacked together with AX742 kits. I need to set up two more switches (same model) in another room. I would like to connect all the switches to cre...
- May 16, 2016
Hi ManuBernat,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
May 16, 2016NETGEAR Employee Retired
Hi ManuBernat,
Thanks,
