klat0n
Apr 05, 2017Aspirant
SNTP KISS IRIG
I do not understand why I am getting this KoD. I did not recieve this KoD packet with the older firmware. M5300-28G-POE+ ProSafe 24-port Gigabit L2+ PoE+ with 10 Gigabit Stacking, 11.0....
DaneA
Apr 06, 2017NETGEAR Employee Retired
Hi klat0n,
Kindly answer the questions below:
a. Have you tried to factory reset the M5300-28G-POE+ switch then reconfigure it from scratch?
b. What device is 192.168.1.1? Have you tried to disconnect the M5300-28G-POE+ switch from this device and check if same error will show on the logs?
c. How is everything connected? It would be best to post a diagram of your detailed network setup.
I look forward to your response.
DaneA
NETGEAR Community Team
- klat0nApr 06, 2017Aspirant
Regarding your question "a." This is not an option because all of the switches that are having this problem are in production.
Question "b." This is a NTP server where all of our devices get is time stamp from. I have tried rebooting and disconnecting the NTP server and the results are the same.Everything is connected by either fiber or copper in a "star" configuration. the NTP server is connected by copper on one leg of the STAR. A map should not be necessary.
