wlud
Jun 17, 2014Aspirant
Stacked gs748ts firmware upgrade
Hi ! I plan to upgrade the firmware of a pair of stacked GS748ts using V5.0.0.23 at this time to V5.2.0.10. Do I need to unstack them or only to upgrade the master which will upgrade the slave ? T...
wlud
Jun 19, 2014Aspirant
Hi !
In fact I DID read this, but it appears unclear to me as it is embedded in a procedure to upgrade from a V3.x.x.x, which is not my case.. as mentioned in my post, I only intend to upgrade from a V5.0.0.23 to a V5.2.0.10..
I should have been more specific : is this applicable for every upgrade or only when you upgrade from a V3.x.x.x to a V5.x.x.x ?
I read long ago that if you upgraded the master switch in the stack it would replicate the upgrade on the others via the HDMI link, but I did not manage to find back where I did read this.. And I do not want to mess with those switches which are very important into our Lan..
Cheers,
Phil.
Cheers,
Phil.
