AliKelman
Dec 01, 2022Guide
Suitable upgrade for an EN108
I've got a patch panel in my home (!) with CAT5 wiring running into various rooms from the patch panel. The patch panel is served by a Netgear EN108 switch. I want to upgrade this to add extra wired...
michaelkenward
Dec 02, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. That includes switches, which don't have much in common with the routers covered here.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
You might like to search there for messages related to your issue .
I will ask the Netgear moderator to move your message.
