AliKelman
Dec 01, 2022Guide
Suitable upgrade for an EN108
I've got a patch panel in my home (!) with CAT5 wiring running into various rooms from the patch panel. The patch panel is served by a Netgear EN108 switch. I want to upgrade this to add extra wired...
michaelkenward
Dec 02, 2022Guru - Experienced User
plemans wrote:
You can go through and select the ones that hit your requirements.
https://www.netgear.com/business/wired/switches/
That's the way to do it.
Switches are mostly basic devices. Not something to overthink. They are in the "install and ignore" category.
How many ports do you need?
Buy the cheapest that fills the bill. Anything will be better than a 20th century switch, designed for the era of dial-up internet.
AliKelman
Dec 02, 2022Guide
Thank you - it all looks pretty straight forward. A Netgear GS108UK 8 Port Gigabit Ethernet Network Switch looks like a suitable one for one replacement. I am still looking for PoE capabilities but I haven't yet drilled through the listings
- michaelkenwardDec 02, 2022Guru - Experienced User
Think forward.How many ports do you need now?
Consider buying the next size up from what you need now. You never know what you might add, and the cost difference between 8 and 16 is small. If you can find 16s.
- AliKelmanDec 03, 2022Guide
Well I opened the cupboard today and found that I have space for a rack mounted Netgear switch to replace my 22 year old EN108. Which will then leave me some extra space in the cupboard. I could probably pick something up off eBay - any ideas of what might be suitable?
- michaelkenwardDec 03, 2022Guru - Experienced User
Good move.
Anything with gigabit Ethernet and enough ports should fill the bill.
