AliKelman
Dec 01, 2022Guide
Suitable upgrade for an EN108
I've got a patch panel in my home (!) with CAT5 wiring running into various rooms from the patch panel. The patch panel is served by a Netgear EN108 switch. I want to upgrade this to add extra wired...
AliKelman
Dec 02, 2022Guide
Thank you - it all looks pretty straight forward. A Netgear GS108UK 8 Port Gigabit Ethernet Network Switch looks like a suitable one for one replacement. I am still looking for PoE capabilities but I haven't yet drilled through the listings
michaelkenward
Dec 02, 2022Guru - Experienced User
Think forward.How many ports do you need now?
Consider buying the next size up from what you need now. You never know what you might add, and the cost difference between 8 and 16 is small. If you can find 16s.
